Could not open default Template file
When I try to apply Shrinkwrap commando I get following message - "Could not open default Template file". See attached picture. What is wrong? How can I fix it? Thank you!
Best,
Roman
Mark.Lancaster
@Anonymous
Do you have the standard.ipt and standard.iam in your location where you defined your Inventor templates?
Mark Lancaster
johnsonshiue
Hi! Like Mark said, this is likely due to lack of Standard template files. Go to Tools -> Application Options -> Files -> Configure Default Templates -> select the standard and unit you use frequently -> Ok. A set of default templates will be created. Then Shrinkwrap should work.
Many thanks!
Software Test Engineer
No, I haven't. That was a solution. Thank you!
amit_pall
Community Visitor
Community Visitor
hello, I have simple solution on it if you find such error, it means there is no templet to default position, so simply copy these template from   C:\Users\Public\Documents\Autodesk\Inventor 2020\Templates\en-US  to  "Templates" folder where you saved your project.
