Corrupt model. Changing frame generator sketches. Rotating Beam.
I posted an issue about this model yesterday.  I thought the problem was related to welds.  I removed all but 4 welds, and removed all beam end treatments.  Corrected some errors that were showing up in sketches.   I finally got the model back up and running with no errors.
Now once again the frame generator sketches are changing for some unknown reason causing problems.  and the last beam that was placed keeps rotating.  I check in frame generator and it states the angle is 0 deg.   ????????????????????????  HELP  whatcold be causing these sketch changes?
CCarreiras
Hi!
Delete the element with frame generator and place it again.
CCarreiras
