circular array
circular array
circular array
After I select cirrcular pattern or array in inventor 2d, I select object to be duplicated and identify the axis, the software won't let me pick the no.
ounits I want to copy around the circle 0r the degrees i want to travel thru.it also wont let me choose okay. Do I have something turned on or
turned off.
blair
Post what you have so far (at least a screen capture), most of the time it's better to pattern the feature than an object on a sketch.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
joe.mills
Hello! Perhaps you are missing a step in the workflow?
After opening the circular pattern dialog:
  1. Select geometry
  2. Right click and the click Continue, or click the Axis arrow in the dialog
  3. Select Axis point
  4. A preview will be shown and the count and degree fields will now be enabled.
If you miss step 2, each additional selection will be adding to the geometry selection.
Joe M.
Software Engineer
