I did a copy design on a model that contained a frame generated frame. I get all these errors. Usually when I do a rebuild all the file fixes it'self but I get the above error every time I try to open the file. All I really know is that it has something to do with the skeleton. Anybody know what's happening.
Not sure how relevant this is below, but as a rule of thumb I stay away from using Copy Design for iParts, iAssemblies, and Frame Generator assemblies:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Vault-Copy-Design-...
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
İt could be 2 Skeleton.ipt in the workspace ? Could you check fiile naming options for copy design ?
Copy Design of Frame Generated assemblies works, you just have to be careful not to "re-use" the skeleton model.
Hard to tell exactly what the issue is that you are having from that image alone.
