I needed to revise a project, but keeping the old version in case needed. We don't use Vault, so I copied the whole folder on windows explorer level and renamed it.
Inventor should not look outside Workspace for files.
When you "look back", did you open files in old folder without switching Project?
If you just copied folder to a new folder in windows explorer it is not surprising to me that there are links to the old that were kept. Vault copy design is the ultimate, but I agree with @CCarreiras in that you should have used pack and go to a different folder and just copy the files.
Or, at the very least, you could have used Design Assistant.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
The procedure you described should have worked for you as expected. Copying an entire project folder and changing the name of the .ipj should make it independent of the original, as long as the workspaces are correct and there's no cross referencing going on.
Are you saying that files in both folders have been altered? Or just in one that you didn't expect?
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
@Frederick_Law wrote:When you "look back", did you open files in old folder without switching Project?
No
@SBix26 wroteAre you saying that files in both folders have been altered? Or just in one that you didn't expect?
Sam B
Yes in both projects, while only working in 1 poject. And vice versa, because I checked the original and saw some part were moved, so I put them back to their correct positions, but then those same parts were moved again in the other project. Just crazy!
Hi! Even if you change the project file name, it does not mean the project will magically points to the new location. You need to edit the project file in Project setting dialog -> check if the paths and folder options are correct.
Many thanks!
Yes both workspace settings pointed to the 2 differenet folders, and still changed both projects
I think you missed something in the process.
I think if you P&G and create new ipj (and use it) - you should not see this issue.
But since you have had an issue, it might be safer using Design Assistant (assuming you don't use Vault) going forward.
Hi! Another option is to use iLogic Design Copy (start up Inventor without opening any file -> Tools -> iLogic Design Copy). You can easily create a brand new dataset from an existing dataset.
Many thanks!
