Copied Assembly
Copied Assembly
nonhlanhlaYJ48B
Copied Assembly
nonhlanhlaYJ48B
Hello everyone, hope you are doing well
I'm looking for some help, I created an assembly for a manure conveyor and then I copied that assembly into a different folder. The issue I'm having is that every time I change the size of the copied assembly my original assembly also changes.
My question : is there anyway to unlink the 2 assemblies.
Side Note- I have tried changing the name of the copied assembly, I even went as far as changing the names of the components that create the assembly 🥲...I don't know what else to do
ampster40
What steps were taken exactly to create the assembly copy?
James_Willo
Hi, we had a similar question asked earlier this week, there are good suggestions in this thread.
https://forums.autodesk.com/t5/inventor-forum/to-copy-and-change-name-of-derive-part/m-p/12729359#M9...
James W
Inventor UX Designer
NigelHay
If the 2 assemblies contain the same parts, changing one would change both. The part you change needs to be unique to the assembly you are changing. You could copy the part to be changed to a different filename then substitute it in the assembly you are changing.
johnsonshiue
Hi! I believe you need to use Copy Design workflow to create a completely independent dataset. Please google "Autodesk Inventor Copy Design." There are multiple ways to do that.
Many thanks!
Software Test Engineer
nonhlanhlaYJ48B
Thank you so much for the responses
I managed to figure out what I did wrong. What I was doing was copying the entire assembly and the separate parts into another folder but what I was supposed to do is use "Save copy as" so that the copy can be its own stand-alone assembly
Thank you for all your help 🙂
James_Willo
Remember that save copy is only copying the top level assembly, it'll still link to all the child parts and sub assemblies. You can move things, but changing the size will affect all assemblies that use those parts.
To do this safely you need Vault copy design, iLogic copy design or design assistant as linked in the thread above.
James W
