My firm has been awarded a project and the client has just added a stipulation after the contract has been awarded. My firm current uses Inventor 2014 and SolidWorks and we do only mechanical (machine design) work, ie. Hydroelectric turbine rehabilitation. Is it possible to convert the models and drawings cleanly or will we have to buy a set of Micro Station and have it as a extra.
Thanks for the help in advance,
Randy Chard
That the design product (drawings,models and assemblies) be delivered in V8. I did not even know that Bentley had a machine design platform.
Mike:
Thank you for your help and advice. I am waiting for a call from a Bentley Application Engineer to discuss or needs. I believe once we go back for the extra money required to pay of the new seat of Micro Station they might just accept the drawings converted at a cost of $4000 (updated our licence to 2014 Suite).
Randy
Hi
First use dwg native Inventor drawing.
For 3d, export the 3d to dwg (IPT and IAM) , open with autocad and export to dgn and for the 2d open directly your inventor drawing with acad and export to DGN
you can use ilogic to automaticly export your 3d to DWg on save
If you want to check your exported file you use Bentley View V8i application
Yannick:
Does your solution require me to have a licence of AutoCad 2oi4 (or the suite)?
The reason I say this is due to the fact the options in your post under export do not exist on mine.
Randy
Change your workspace to 3d modeling
If they're asking for MicroStation format explicitly, they likely expect to receive "intelligent" models. Your solution will produce "dumb solids" with no modeling history.
it's the best we can make or he must purchase BMS seat
Yannick:
I am not sure where I would do that. I have attached a file that I currently have open on my monitor. I cannot seem to find the options that you have!
Sorry but you need autocad to export you dwg to dgn
Yannick:
Thanks. That is my fall-back if the client only wants the 2D drawings. It seems that if they want intelligent data then we will need to buy a seat and training and back charge it to the client, along with the reduction of productivity until one of us is up to speed on that new platfrom.
Randy
