Converting lines to surfaces, "close to offset tool"
matous_hala
matous_hala
Community Visitor
Community Visitor
Hello, I have a quite complex sketch geometry (as shown in the picture). I would like to make the lines "thick", or rather I want them to be paths of sorts, so I could extrude them, and 3d print them, because you can't 3d print lines only as far as I know, they have to have some thickness. I need something like the offset tool, but that doesn't seem to work for such complex geometry. It's a line art that I want to 3d print, but as the name line art suggests its made only from lines.
the sketch cannot be printed on a 3D printer
there are two ways here
1 long: create a plane perpendicular to the line. draw a circle, shift along the path
2 quick: transfer sketch to assembly
frame generator select the frame and put the sketch
3 save as stl - print
johnsonshiue
Hi! There are ways to do this using Rib command or Grill command in Plastic Features. Another option is to use Fusion 360, which supports Thin Extrude.
Many thanks!
Software Test Engineer
