Converting .iam to .stl
Message 1 of 8
I have a couple of students that are trying to convert a ".iam" to ".stl".  I am having no luck doing this.  I am attaching an example.  I want to 3D print their file.
Thanks for your help!
Michael
Replies (7)
Message 2 of 8
JDMather
An assembly file (*.iam) must include parts (*.ipt).
Attach your part2snowflake.ipt here.
Should be as simple as Save As>Save Copy as type *.stl (be sure to select Options and set Units to document units).
Message 3 of 8
Hello Again,
I am probably doing something wrong, however, when seeing the drop down menu for Save As>Save Copy as type *.stl (be sure to select Options and set Units to document units).
.stl is not an option. I have only seen this as an option for export- CAD Format.
Michael
Message 4 of 8
JDMather
You did not attach the part file here as instructed?
Whether you do a Save Copy As or you do Export - you should see the same thing.
Post screen shot of what you do see.
Also, check your Tools>Add-Ins
Message 5 of 8
blair
I've posted a link to a ScreenCast: https://autode.sk/2znhzCE
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 8
When my student goes to Export; CAD Format; the ".stl" is available.  However, when he tries to send it to me the file is not in his folder where we saved it.
Message 7 of 8
JDMather
No part file attached here as requested???
Export as High resolution rather than Brep.
Try saving to some other location (perhaps the Desktop) where it can't be missed.
Message 8 of 8
blair
Have him save it to his "Work" folder as defined by the Project File. This could be an issue with permissions.
Or have him create a new folder within his "Work" folder and export/save it there.
Delta Tau Chi ΔΤΧ
