Parametric tube Help!
Good day all!
This is probobly quite an easy task but I am stuck!
I have a tube:
What I want to do is make a parametric value for the lenght of the extrution.
The only way of doing this I have found is to make it into an Ipart and set value off the extrution:
However this limits me to the preset values I have made.
What I need is a way to set the lenght to X. And every time I place it into an assembly I get a question eg."What value do you want for X:"
Is there an easy way to achieve this?
If there is a good guide for this kind of stuff a link to that would be very welcome also!
Have a good evning
lmc.engineering
Hi @Anonymous
There are two easy ways to do this.
Using the iPart table, if you right click the Length parameter column, you can select 'Custom parameter column'. Now when you insert the iPart in to an assembly, you'll be able to modify the length accordingly.
My preferred way is to simply create the part with a named Length parameter and use the 'Place iLogic Component' when placing in to an assembly. You'll be given the option to change any parameter when placed. Note that the iLogic placed part file will become a new part, and saved in the root folder of the assembly you are placing it in to.
Hope this makes sense.
cbenner
@Anonymous
Have you looked at using Tube & Pipe?  Can you offer an example of how you are using these tubes, and how often you need to do it?  T&P may or may not be your answer.  If it is, we can certainly help you get started.
Yeah I am familiar with T&P. However this was just one type that I needed. Had it only been tubes/pipes I would have used T&P. Thanks for the suggestion though.
Also it is now resolved thanks for the help the both of you!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
