Hi!
I need all the views from attached connectors.
Can somebody convert attached files (DIN 8 connector) to 2D .dwg or .dxf?
Thank you!
Solved by Mark.Lancaster. Go to Solution.
Do you have Inventor or AutoCAD Mech? Both can import step files and then you can make the drawing yourself?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Mark.Lancaster wrote:Do you have Inventor or AutoCAD Mech? Both can import step files and then you can make the drawing yourself?
Hi Mark!
No, I don't have them, that's why I ask for help. Unfortunately the supplier of these parts doesn't have their .dwg or .dxf drawings but the .step.
By the way I'm using Autocad 2016 LTD.
Thanks in advance.
Here you go..
Mark Lancaster
