Inventor Forum
Convert -igs to .dwg
15 REPLIES 15
Message 1 of 16
4126 Views, 15 Replies
a friend send me a File but it is imposible to open it.
could somebody convert this to .dwg ?
Greetings
Lukas
15 REPLIES 15
Message 2 of 16
Message 3 of 16
JDMather
Right click on the filename.
Select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Message 4 of 16
in reply to: JDMather
great thanks!
Message 5 of 16
Is this all you're trying to do?
Message 6 of 16
Oh, i think it is more..
tanks !!
(do you have some tools to convert Sketchup Models (.skp) to .dwg Files? so I could do this on my own 😉 )
Message 7 of 16
All I did was start up autocad and go to Insert>Import>External File>IGES File...
Autocad probably has the ability to import those as well but I cannot say I've ever tried.
Message 8 of 16
How to convert .igs file to .dwg.
i was not able to do with any of the above solutions
Message 9 of 16
i was not able to do this way. i have autocad 2016. Any help
Message 10 of 16
JDMather
Zip and attach the file here.
Message 11 of 16
Thanks. It was not working because i was working on MAC. i switched to windows. It works fine now. Thank you.
Message 12 of 16
OmniCardoso
Hello all, I am trying to open an IGS file, but AutoCAD won't open it. Could you teach me how to convert it to DWG? Thanks!
Message 13 of 16
johnsonshiue
in reply to: OmniCardoso
Hi! This IGES file was exported from Catia. It seems to contain a solid body or surfaces. I can import it to Inventor 2022  as a solid body without a problem. Then export it to an AutoCAD dwg file.
What was the error you saw in AutoCAD? It should work.
Many thanks!
Software Test Engineer
Message 14 of 16
JDMather
In AutoCAD run the IGESImport command.
Message 15 of 16
OmniCardoso
JDMather, IGESImport worked perfectly, thank you so much!
Best Regards
Message 16 of 16
OmniCardoso
in reply to: johnsonshiue
I tried the IGESImport JDMather told me about, and it worked very well.
Didn't use your method because I don't have Inventor, but thank you so much for the attention!
