Convert CC Part To Normal
edonline69
Message 1 of 23
edonline69
Would/Could someone out there take the attached CC part and convert it to a normal part please. I've tried all the marco's/ilogics I could find but can't make it work.
Please covert to INV 2016 (no greater)
Thanks in advance!!
Ed
Replies (22)
Message 21 of 23
Mark.Lancaster
Here's what I suggest
Using the Content Center editor...  Edit this washer's family table and add a row (copying/pasting the existing one) and define your material you need for that instance.  Then you will need to add the material column as a key column so the material field will appear in the place from content center dialog.  You will also need to change file name structure as well so it incorporates the material info in it.
Then you can do a change size function and select the replace all option.
Just another option...  Smiley Wink
Mark Lancaster
Message 22 of 23
-niels-
The code i used needs to be run in an assembly:
You place the offending part in an assembly, select it and then run the code.
I've skimmed the other posts (here and in the topic i linked) and it seems there is more code floating around for the same purpose, but since these parts are really locked down the "run from assembly" code i use seems to be the more functional one...
It's kind of funny to see such a legacy problem pop up again more then 10 years later.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 23 of 23
edonline69
Niels,
You are crowned the "Mad Scientist" Smiley Very Happy
Thank you and all of who offered assistance for your help.
Ed
