Hi! I don't think there is a command to convert or project a workaxis to a line in 3D Sketch. You will need to create a 3D line and apply colinear constraint between the line and the axis.
Many thanks!
Hello @lkirit2000 you could create a 2D Sketch (on an Origin Plane) and Project Geometry of the Axis there.
Then within the 3D Sketch you can Project Geometry gathered in the 2D Sketch.
A few more steps but should get you the Axis to work with.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
Hi Kelly,
Thanks for your response.
Rgds
Kiri
