Content Centre Assemblies
dleigh2GBTW
dleigh2GBTW
Hi all
With the new ability to publish assemblies to the Content Centre, Anyone know if you can create a simple Bolt assembly with a bolt, Nut and 2 washers (all from the Content Center) and be able to have different options of bolt size that will change all sizes
Donald
SharkDesign
Why don't you just use autodrop? It's pretty quick and will work perfectly without you having to adjust the distance between washers etc
  Inventor Certified Professional
kacper.suchomski
I'll add that the screw wizard allows you to save a template so you don't have to search for the same standards again. You can load such a template at any time during the process and specify the positions, just as you would when inserting screw connections normally through the wizard. This gives you complete flexibility regarding the location, number of occurrences, size, and spacing of screws.
I see no point in reinventing the wheel and duplicating available functionality at the expense of your own time.
Kacper Suchomski
