How to display Part Number + Description in Assembly Browser?
tecnico3ZDE6R
tecnico3ZDE6R
I am working in Autodesk Inventor with Vault and using a coding system where:
File name = progressive code
Part Number = same code
Description = readable name
In the Assembly Browser, I currently only see the file name (or part number), which makes it difficult to navigate because I see only codes (e.g., 00200001).
I would like to display something like:
Part Number + Description (e.g., 00200001 – DN50 Pipe P235GH)
In Solid Edge this is possible, but I cannot find a way to do it in Inventor.
Is there:a built-in option to customize Browser Node display?
or an official method to combine multiple iProperties in the browser?
I am looking for a clean and stable solution (preferably without manual renaming).
Thanks in advance.
Michiel.Valcke
You can do this with some simple iLogic Rules:
How to modify the component names in Inventor model browser : Geo-IT (Dutch)
This iLogic Rule will give you the part numbers in the model browser:
Sub main()
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences)
On Error Resume Next
Dim oOcc As ComponentOccurrence
Dim lngPos As Long
Dim IndexValue As String ' Renamed from "Index" to "IndexValue"
For Each oOcc In Occurrences
If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
Call TraverseAssembly(oOcc.SubOccurrences)
lngPos = InStrRev(oOcc.Name, ":", -1)
IndexValue = "" ' Initialize IndexValue variable
IndexValue = Trim(Mid(oOcc.Name, lngPos, Len(oOcc.Name)))
' Use the renamed variable to update the occurrence name
oOcc.Name = oOcc.Definition.Document.PropertySets.Item(3).Item("Part Number").Value & IndexValue
Next
End Sub
This iLogic Rule will give you the Description in the Model Browser
Sub main()
End Sub
    Dim lngPos As Long
    Dim IndexValue As String ' Renamed variable from "Index" to "IndexValue"
        IndexValue = "" ' Initialize the new IndexValue variable
        oOcc.Name = oOcc.Definition.Document.PropertySets.Item(3).Item("Description").Value & IndexValue
    Next
End Sub
This iLogic rule will give you PartNumber & Description in the model browser:
Sub main()
End Sub
    Dim lngPos As Long
        oOcc.Name = oOcc.Definition.Document.PropertySets.Item(3).Item("Part Number").Value & " (" & oOcc.Definition.Document.PropertySets.Item(3).Item("Description").Value & ")" & IndexValue
    Next
End Sub
tecnico3ZDE6R
OK... but its sound like workaround.... Solid EDGE is Better!
Michiel.Valcke
https://help.autodesk.com/view/INVNTOR/2027/ENU/?guid=GUID-C5ADE109-10E9-41A0-BC4A-BE73AA68A1C7
In the manage tab, click add external rule, save the rule. You can set a trigger to apply it each time an assembly is saved/opened/created/ ... or you can run it manually.
johnsonshiue
Hi! Another tool to look into is Mighty Browser by coolOrange. It is a free app available at Inventor App store.
https://marketplace.autodesk.com/apps/3c0dc11b-d07c-47d4-b8a6-6b5d7ed2e99c?priceId=40f569d1-986a-476...
Many thanks!
Software Test Engineer
