Content center relocation to shared drive issues
The initial problem I was having is that I have a laptop and desktop and open my inventor files on both, from a company shared user drive. When I do this the Content Center parts will not transfer between computers since each computer reads from its local file location for Content Center parts. This means I have to resolve any Content Center parts anytime I open a file on a computer other than the one it was created on.
I tried to copy the Content Center file onto the company shared user drive, which both my computers should be able to read from, and redirected the Content Center location pathway on the application settings to this file location. This was done in the application settings on both the Content Center tab and the File tab (see attached photos). However when I click OK a pop-up warning says "No Content Center library exists in the selected location".When I go to an assembly and try to place a part from the content center, nothing appears for me to select. This warning and issue persists even when I try to switch both pathways to back to their original settings.
How can I get the Content Center to exist and read from a shared file location or at the very least get the original Content Center settings reinstated so that I can at least use it?
Content center tab file pathway editContent center tab file pathway edit
File tab  file pathway editFile tab file pathway edit
warning pop-upwarning pop-up
 Empty content centerEmpty content center
Mark.Lancaster
@Anonymous
Tools/Application Options/Content center tab indicates the location of your desktop content center .idcl files
Tools/Application Options/Files tab indicates where the content center component gets placed once its pulled from content center.
Right now you're confusing the settings and the two library .idcl and the actual content center .ipt should be separate.
I might suggest that you read this article too https://synergiscadblog.com/2014/02/28/working-with-inventor-content-center-part-1-of-3/
Mark Lancaster
Thanks, I go it squared away.
