Inventor Forum
Content center problem with server
1 REPLY 1
168 Views, 1 Reply
I try to insert a bolt with content center and I got this message : There was a problem encoutered while communicating with the server. Please check the network connection and serverr status.
I check my connection status, and I'm connected so..any idea of the problem?
1 REPLY 1
Badari [Autodesk]
I saw the 2 pictures attached. The server status is okay, as you are still connected to \\sql1.
Is \\sql1 locslhost or a remote server?. However, the error could be because of a Network issue. Check if the WWW services & SQL AutodeskVault instance are up & running on \\sql1.
Hope this helps,
Badari
