Content center Part Name problem
JorisSteurs1246
JorisSteurs1246
Content Center problem....
Can anyone explain why the material code shows twice in the part name,while I clearly have set the Part Name to be equal to file name?
Pic attached.
cbenner
Pic attached.
The short answer is... What?!
Try highlighting the entire column and deleting the contents.  This will delete anything that is not following the rule set in your column properties, and replace it.  I don't really see how that could be the problem, but to eliminate it as a possibility, you should try it.
JorisSteurs1246
Yes copied it over to another library and deleted all partnumbers, that has helped. I was thinking there was a hidden setting or so , but clearly it must have been a form of pollution  😉
