Hi Rmeyers,
Well without the part its hard to tell if you have a completely closed loop for the Coil.
(I assume it is based on the photo)
That said if you want to do a solid fill on the coil part, you can project the edges that are open.
In the bottom sketch that you already had started, project the top edge and the bottom most edge.
Since this looks like its 245 -270 deg and doesn't cross over its self, you should be able to extrude "to next".
After that you should have the proper fill.
If you still need help, post the part and I can do screen captures to show you. (or provide the finshed part if you have 2016)
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
