content center opening error
lkirit2000
Advisor Advisor
lkirit2000
Hi
When I some some assy files, the content centre components gives an error message. it causes time delays.
Please see the attached image.
Kiri
BDCollett
The Project file location needs to be the same as where the files were when saved.
It looks like you might be using default.ipj?
lkirit2000
Yes, you are corrrect.
I moved from network drive to one drive.  How to fix it.
johnsonshiue
Hi! If I were you, I would map the One Drive folder to a logical drive. Then change the Inventor project setting (Folder options -> Content Center Files -> select the mapped drive). Where are the library files stored?
Many thanks!
Software Test Engineer
lkirit2000
Hi Johnson,
Good Morning.
Appreciate your feedback.
Please explain more what is logical drive ? where it is ?
How to see where is library files are ?
Kiri
BDCollett
@lkirit2000 wrote:
Hi Johnson,
Good Morning.
Kiri
A logical drive, like a location on C:/ that is not sync'd with the cloud (OneDrive)
You will need to fix the association for the assembly you are opening if the location has changed.
