Constraints freezes the part
This widget could not be displayed.
Hello!
This is making me nuts!
When I place ONE constraint between two parts, I cannot place a second constraint. The parts are already frozen.
I cannot drag around the parts. It doesn't matter what type of constraint it is. For example: I place a constraint with two holes together, I should be able to turn one part around this hole. But I can't. When I try to drag it around, there is a symbol like this Ø that normally appears when all possible constraints are set.
Please help me. I have lost almost a day of working because of this. This problem occured yesterday. Before that, I had no problems.
Kind regards
David
Replies (25)
Thank you for your help.
But I still think it's very strange though. I have made bigger assembleys before without any problems.
I agree that this small  assembly is behaving strangely,
but you seem to have some issues with unrelated constraints. Creating a good
workflow using subassemblies minimizes the possibility, and also helps when
troubleshooting. Subassemblies improve large assembly performance and
speed.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP2, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
denl
Archived Account
I logged this issue into our tracking system as DID # 1150251.
Thanks.
Lisa Den (Autodesk)
LichaoYu
The problem is caused by part S1-1293-13.ipt. See the attached picture. When you apply constraint, you assume the two faces are perpendicular to each other. But the actual angle between these two faces are 89.999848 deg.
Lichao Yu
Thanks for the sharp eye!
Expert
Expert.
PcCillin AV
XP
Good catch on part -13....
Expert
Expert.
PcCillin AV
XP
