Constraint two wheel to cross a random Path
Message 1 of 60
Good Morning to everyone! I've a problem with a guide who have to cross a random path. I've used the transitional constrant but it doesn't worked. Sorry for my bad english, i'll post below  my system in a .zip file so it will be easier to understand what is the problem.
I'll post even a screen of my system
Replies (59)
Message 2 of 60
Cris-Ideas
So solution to your problem actually does NOT exist in inventor.
Sorry to pass this news. ☹️
[video]
for much more detail over how constrain solving DOES NOT work in Inventor please visit this threads:
Flexibility not working properly in inventor - BUG that has been there for ever
Constrain solving - as complicated as that
Cris.
Cris,
https://simply.engineering
Message 3 of 60
Thank you very much for the answer and for the video 🙏🏻. I’ve understood which is the problem and it’s so incredible that a software like Inventor has this problem
Message 4 of 60
JDMather
@Anonymous wrote:
... it’s so incredible that a software like Inventor has this problem
@Anonymous
Works fine on my computer.
Environments>Dynamic Simulation.
Message 5 of 60
Ok, @JDMather thank you very much for the answer, but now i've another question and problem. If i put another set of wheels, as the first one in the figure, and I try to move them, as a "car", they don't work again. The system is this below:
I've attached also the CAD file if you want to try, please. In this case, what can I do? I need of this for my thesis
Message 6 of 60
JDMather
@Anonymous wrote:
I need of this for my thesis...
I noticed that many of your sketches are not fully defined.
I make sure that my students can fully define a sketch before proceeding into an advanced topic like Dynamic Simulation.
Are you ready to start over from the beginning?
Message 7 of 60
@JDMather  My sketches are not fully defined because this is just “trial” of what I want to do. But before to do it, I need to understand how to make it. I’m sorry if my sketches are not fully defined, but I’ve made this quickly because I need to understand if I can realize that motion or not
Message 8 of 60
JDMather
That didn't answer my question.
Are you ready to start over?
Message 9 of 60
Sorry i haven’t read. Yes, I’m ready. I need it.
Message 10 of 60
johnsonshiue
Hi! I believe this is a limitation and a bug in Inventor. Transitional constraint does seem to like multiple transitioning faces at the same time. It can fail easily. I tried a slightly different solution and it seems to work better. Instead of using cylindrical faces, I used spheres. The spheres seem to work better. Please take a look at attached file.
Many thanks!
Software Test Engineer
Message 11 of 60
@johnsonshiue Thank you very much for the advice. Now, I'm trying to solve the problem with 2 axes and 4 wheels
Message 12 of 60
Cris-Ideas
@johnsonshiue
Hi Johnson,
So I took a look. Problem is exactly the same with spheres, cylinders or any other shape you can think of.
It is the same thing that causes problems with FLEX and POS REPS and even in flat assemblies.
Cris
Cris,
Message 13 of 60
JDMather
We will go through each step, one-by-one and diagnose as needed.
Open the file Binario.ipt
Edit Sketch1 and add missing dimension(s)/constraints to fully define the sketch.
Message 14 of 60
JDMather
Right click on Sketch2 and select Redefine and then select the YZ Plane.
Delete WorkPlane1.
Edit Sketch2 and add missing dimension(s)/constraints to fully define the sketch.
Message 15 of 60
@JDMather Ok, i've made it. Maybe i've understood the "key" of this. The parameters, right?
Message 16 of 60
JDMather
Attach the corrected part file here.
Once I have verified that you are following my instructions we can move at a faster pace towards a solution in Dynamic Simulation.
Message 17 of 60
Ok, i've a question. Are only these two the parts that i have to correct ? Or have I to define fully each sketch made by myself?
Message 18 of 60
JDMather
Before I proceed to Dynamic Simulation - I will have to examine each and every component.
So all parts will have to be correctly modeled.
Message 19 of 60
The fixed files are below
Message 20 of 60
JDMather
I opened the first file in the folder - Edit Sketch1 and do not see any dimensions?
