"AgCyanide" wrote in messageHey
href="news:6053199@discussion.autodesk.com">news:6053199@discussion.autodesk.com...
guys and gals...
I'm having a problem with Inventor Suite 2009 SP1,
wherein, I have two holes on a hinge that are 1.8898" apart, and two Pem Studs
on the mating door panel that are also exactly 1.8898" apart, vertically
aligned, and fully constrained in the related sketch.
Now, when I place
an Insert Constraint on the top hole on the inside of the panel, to the
Hinge's corresponding top hole on the outside surface, it places the door
panel on the hinge. No problem.
When I place either an Insert
Constraint in the same fashion as above to the second hole, or a Mate
Constraint to the axis of the shaft of the Pem Stud and to the second hole in
the hinge, the constraints "blow up" and generate a list of conflicting
constraints.
This should be a simple thing for Inventor to
do.
What gives?
Thanks in Advance. [Edit]-jpegs of problem
attached[/Edit] Edited by: AgCyanide on Oct 16, 2008 4:32 PM
