In Inventor 2021 when a constraint fails you can edit it and the missing geometry selector green or yellow would be highlighted and you just need to select the missing geometry.
This is no longer the case in 2022 and one has to select either the green or yellow selector fist and then the geometry.
Please fix this or resort to how it used to be and now you have introduced another click and this takes time when a large amount of constraints have failed.
See pic below.
Solved by johnsonshiue. Go to Solution.
Hi Anthony,
Yes, this looks like a bug to me. I can reproduce it. The issue is that somehow the selection state is not enabled, while the selector button is indeed pressed. I need to work with the project team to understand it better. In the meantime, it has been reported as INVGEN-52214.
Many thanks!
