Constraint error VEX Robotics V5 Bearing Flat to C-Channel
orrd8V2PP
orrd8V2PP
I am encountering an issue with constraining a VEX Robotics bearing flat to a c-channel. Here is a video where I explain the issue: https://app.screencastify.com/watch/R8LmDNXPqliBYaDaqUAd
What am I doing wrong? What I am attempting to do was not an issue in the past with older versions of Inventor.
Any help would be appreciated.
Thanks in advance.
kacper.suchomski
Hi
Can you attach files?
Kacper Suchomski
orrd8V2PP
Are you referring to the video I provided via link or files from Inventor?
kacper.suchomski
Inventor files.
Kacper Suchomski
orrd8V2PP
Here is a zip folder of the files from Inventor ("Pack and Go"). Hope this is what you are looking for. Thank you for your help.
kacper.suchomski
The faces are not perpendicular.
Kacper Suchomski
orrd8V2PP
Thank you very much! I appreciate the quick and easy to follow solution!
