Inventor Forum
Constraint Dots
9 REPLIES 9
Message 1 of 10
cadcamm99
1020 Views, 9 Replies
Constraint Dots
I have Inventor 2012.  When I work on a new model, I have the Yellow and Green dots when sketching.
However if I work on an older model, the dots do not appear.  I have everything on. See attachments.  Not sure what else to check.
9 REPLIES 9
Message 2 of 10
in reply to: cadcamm99
On an existing sketch you will have to use show constraints to see the conincident constraints (yellow boxes).
Message 3 of 10
cbenner
Message 4 of 10
cadcamm99
in reply to: cbenner
Actually didn't mean the grips.  I meant the yellow dot that follows the cursor and the green dot that shows up when your cursor is on an end point, midpoint or intersection point.
Message 5 of 10
mrattray
Mike (not Matt) Rattray
Message 6 of 10
ampster40
in reply to: mrattray
OP's first pic shows those already set.
Just a guess since you mentioned older files, is it possible these files have not been fully migrated or saved up to the latest version you are using?
Message 7 of 10
cadcamm99
Turns out it is my part that is causing the problem.  After leaving Inventor and going back into it, things went back to normal.  However the more I worked with the part, it became progressivly unstable.  Not sure why part is doing that.
Message 8 of 10
ampster40
if possible, post your file/s here for others to look over.
I don't have 2012 myself, still on 2011 but maybe someone else can take a peek into your model and prehaps find something odd in there.
Message 9 of 10
mrattray
in reply to: ampster40
Oops, missed that.
Message 10 of 10
Have you done a rebuild on the part?
