Am I able to create work points in a 2D sketch in an assembly and then constrain a component to it after I exit the sketch?
Solved by DRoam. Go to Solution.
No..
You can only add workpoints in an assembly to a sketch point created in the IPT.. Not assembly level sketches..
Am I able to make a design using work points and then constrain the component to those points? The points in the work features tab.
Building on what mcgyvr said, here's a workflow that might work for you:
Hopefully that accomplishes what you need. 🙂
