Constraining arc with an angle and radius.
jatin_sanskrit
jatin_sanskrit
How do we constrain an arc using angle and radius given that the arc is symmetric around an axis. For example refer to the attached part. I have constrained the smallest arc R50 with radius and angle, and symmetry around the Y axis. But to achieve this, I had to draw the construction lines to specify the subtended angle. Is it possible to apply the angular dimension for the arc without creating those construction lines ?
kacper.suchomski
Hi
You can click 3 points - end of arc, center, end of arc.
But your practice is very good.
Kacper Suchomski
jatin_sanskrit
Wonderful. Thanks.
