Inventor Forum
Constrain Problem
2 REPLIES 2
358 Views, 2 Replies
Constrain Problem
The software that I have installed is not constraining properly as the constrains make the other object sink into another , which is frustrating for projects. I have continuously changed everything about the objects , even my placements, but nothing really works. Is this a problem with the software as I suspect it may be.
Tags (2)
2 REPLIES 2
jtylerbc
I doubt it's the software itself, but it's a little hard to tell exactly what you have going on just from your description.  Can you show some screenshots of what you're seeing?
JDMather
Attach your Inventor files here.
I have been using Inventor for 15 years and do not recall the behavior that you are describing.
Can you make a Screencast recording of the behavior?
