I made a V12 engine, the problem is: when i made the constrain between the parts they locked in a group and cant rotate the crankshaft. Did i miss something or the constrain sequence is wrong?
Solved by WHolzwarth. Go to Solution.
@Anonymous wrote:
.... Did i miss something...
An assembly must include parts.
Do you have a sub-assembly that you have not set to Flexible?
In the assemble there are individual parts, only the piston rod hat got several parts(piston rod lower/upper, and 2piece bearing).
how can i check or set it to flexible? I dont understand that sub-assembly, can you explain it?
@Anonymous wrote:
In the assemble there are individual parts, ....
Did you attach any of those parts here?
Posting an iam file is useless if you do not also include all ipt files and any subassembly iam files with it..
The iam file just links to all parts/subs and does not include them in itself..
Example..
If you have 2 parts in an assembly you must zip (or use Inventors pack and go functionality) so that you attach those 2 ipt files and the iam file here..
That's not all.
Part17 missing
Part18 missing
Connecting_rod_bearing missing
Bolted Connection is missing too, but not really needed.
Walter Holzwarth
This should do it (2015 files). I've seen several issues:
- Not fully constrained sketches
- First parts in IAMs were not fixed
- Underconstrained IAMs
And Insert constraint is easier to look over than a combination of Face mate with Axis mate.
Walter
Walter Holzwarth
Thanks a lot!
Its work perfectly.
I try grounded my version's first element and worked well, same as yours solution.
