Constant issues with file status checkouts
graeme_robinson
Message 1 of 10
graeme_robinson
Hello
We have constant errors with files being in dirty states, but the biggest issue is when a file cannot be saved as it's checked out by the user trying to save the file, which doesn't make much sense.  Any ideas?  I cannot post files as they are confidential but screenshot is self explanatory
G
Replies (9)
Message 2 of 10
Alexander_Chernikov
Do you use Vault or Single User Project?
What version and updates of AIV?
What about the properties of Design State?
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 10
graeme_robinson
Evening
Its using a shared project, Autodesk  Inventor 2022.3.1, no vault at the moment
Never looked at design state iprops, never changed them.
G
Message 4 of 10
johnsonshiue
Hi! Does the behavior change if Refresh command (File -> Manage -> Refresh) is used?
Many thanks!
Software Test Engineer
Message 5 of 10
pcrawley
There's a separate browser tab for shared project file status.  (Unfortunately, the Design state iProperty doesn't reflect the shared project check in/out status.)
Does the file status indicate a green box with a tick showing you're allowed to edit the file(s)?
If not, it may display a message that indicates why you're seeing that message.
(Shared projects add extended entity data to every file so they can sort-of-manage who is editing each file.  This data isn't visible anywhere other than inside Inventor - so it can be a pain to unravel.  If you ever choose to move to a 'proper' multi-user file management tool like Vault, use Autoloader to get your data into Vault because it is - as far as I know - the only tool which strips the shared project garbage from all your files.  I guess there's a reason shared projects were made 'legacy' at least 10 years ago!)
Peter
Message 6 of 10
Alexander_Chernikov
The latest update for this version is
Inventor Professional 2022.4.1 Update
Try to update (for ex, via https://manage.autodesk.com/ ).
Facebook | LinkedIn
Message 7 of 10
NigelHay
We used to have a problem with not being able to save files because they were checked out. We fixed this by changing everyone's user name to 'user' in 'Tools, Application options, general' (there are only 3 of us using Inventor). Not had the problem since.
Message 8 of 10
graeme_robinson
Personally i use Vault, but where I am situed at the moment it is not possible t use vault.
i seemed t remember years ago I used unreserve which doesnt work any more sadly
G
Message 9 of 10
graeme_robinson
yes indeed, the box in file status looks exactly like that
G
Message 10 of 10
graeme_robinson
its been doing this for nearly 20 years.  Cant update as IT dont allow it, upgrading soon to 2023
G
