Connector Class
Connector Class
jelica.rakovicJY7DU
Message 1 of 11
Connector Class
jelica.rakovicJY7DU
Hello everyone! I need some help with connector class. I know how to transfer the parameters between models in Assembly, but parameters which I put in Assembly transfer from first to second model and I need it the opposite way. I want them transfered from second to first model. For example, when I put my first model with the parameter ROLLER = "OFF" and connect second model with the parameter ROLLER = "ON", I need the parameter ROLLER from the first model to change its value to ON, as parameter in the second model.
Replies (10)
Message 2 of 11
CCarreiras
HI!
Can you post the models?
CCarreiras
Message 3 of 11
jelica.rakovicJY7DU
This is my models.
Message 4 of 11
A.Acheson
One method is a ilogic rule like so. In the main assembly place ilogic rule. Change Part1:1/Part2:1 to your occurrence names.
If Parameter(Part2:1,"ROLLER") = "ON" Then
Parameter(Part1:1,"ROLLER") = "ON"
End If
Regards
Alan
Message 5 of 11
jelica.rakovicJY7DU
Thank you for your reply. I need it to be automatically, because I have more models which I put in my assembly, and change those parameters in factory properties. So, when I connect first to first model I need models without rollers, ROLLER=OFF, and when I put second to first I need roller from that side.
Message 6 of 11
A.Acheson
You could have a rule to run on save or manually to loop through occurrences and check for the parameter and if found change its value.
  Dim Position as String = "On"
   'Get the active assembly.
    Dim AsmDoc As AssemblyDocument = ThisDoc.Document
    'Get the assembly component definition.
    Dim AsmDef As AssemblyComponentDefinition = AsmDoc.ComponentDefinition
    'Get all of the leaf occurrences of the assembly.
    Dim LeafOccs As ComponentOccurrencesEnumerator = AsmDef.Occurrences.AllLeafOccurrences
    'Iterate through the occurrences.
 For Each Occ As ComponentOccurrence In LeafOccs
		Dim occDef As PartComponentDefinition = Occ.Definition
		Dim OccDoc As PartDocument = occDef.Document
		If  OccDoc.IsModifiable Then
			Logger.Info(Occ.Name)
            Dim Params As Parameters = occDef.Parameters
            Try
           Params.Item("ROLLER").Value = Position
            Catch
            End Try
		End If
    Next
It is a little hard to follow your workflow so if you want more assistance please post some images of the browser tree and changes to be made and a list of where the models are in the main assembly.  Maybe you want all parameters to match occurrence 1 parameters? If so that is possible.
Regards
Alan
Message 7 of 11
jelica.rakovicJY7DU
Thank you for your reply. This code didn't work in my case. I will try to explain in details. In the first image it is two of first model, and when you connect first to first model my parameter ROLLER must be OFF. And that is ok with me. In the second image it is first model which connects with second model. In that case, first model must turn on the ROLLER  on the side it is connected to. And in the third image there are final models with the values I need. I can do this manually, but I need it to be automatic, because I have too many models in my project, and I can't change that parameter manually.
Regards
Message 8 of 11
A.Acheson
Here is an update to this .
Logic is the following.
First/Second Model Combination
If Second Model in assembly Then
First model parameter of Roller_2 = ON
End If
	Dim RollerRight As String
			'Look for second item in the assembly.
			If Occ.Name = "Second_Model:1" Then
				RollerRight = "ON"
			End If
	 Next
			'Control first model based on second model being in the assembly.
			If Occ.Name = "First_Model:1" Then
	            Try
	           		Params.Item("Roller_2").Value = RollerRight
	            Catch
	            End Try
			End If
	 Next
Regards
Alan
Message 9 of 11
jelica.rakovicJY7DU
It's work! But, I have another problem. In the rule are written, the numbers and names of first model, and the numbers and names of the second one in assembly. If I put more than one model, that rule that you sent me, makes no sense, because I do not know the exact number of models which I should put. Example is on image. Is there a way to pass parameter without models name?
Regards!
Message 10 of 11
A.Acheson
That is correct as the occurrence name is always placed with the index value of the number of occureences in the assembly.
A change to use the function string.contains method should work for this. You only search for the portion of the string that is static.
If Occ.Name.Contains("Second_Model")" Then
   RollerRight = "ON"
End If
Regards
Alan
Message 11 of 11
jelica.rakovicJY7DU
It's work! Thank you!
Regards!
