Hi
How do connect to / setup newsgroups? I remember doing this yrs ago for ME Access but I had to use outlook express. Outlook doesn't do newsgroups.
What's the best way and what are the curls?
Nacho
kelly.young has edited your subject line for clarity: Newsgroups
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Solved by rhasell. Go to Solution.
Hi
For outlook you can subscribe to the RSS feeds.
hmmmmm
when i click on the "subscribe to RSS" on the Inventor page, i get a xml version of the page but nothing that helps me subscribe. When i try to go to add a RSS in outlook, i need to point it a an xml page...
Am i missing something?
Nacho
Well now that you mention it...sorry.
It's been a while.
I use an older version of outlook, (2010)
What I did
In the subscribe window, I copied the URL.
I then created a RSS feed in outlook
I pasted the URL into the outlook RSS feed.
Nacho
Hi
I just copied the url as shown in the screen cap. (It has the rss in the link)
I did a test to check the full process with the licensing board:
https://forums.autodesk.com/autodesk/rss/board?board.id=24
That worked 100%
What version of outlook are you running, it may be a different process.
