Inventor Forum
Component Visibility
2 REPLIES 2
yalcon7XU75
218 Views, 2 Replies
Hello, I have a visibility problem with an assembly
that I am incorporating to assemble an architecture
in Revit, my workflow begins with the modeling of
some parts in Inventor, then I import those parts to
Plant 3D to assemble the assembly and later I import
that assembly to Revit, the problem is that the
components that come from inventor are seen in the
Revit model as a wireframe model and not as a solid one,
and I don't know what I should adjust in the tools.
I would greatly appreciate your help.
Labels (2)
2 REPLIES 2
johnsonshiue
in reply to: yalcon7XU75
Hi! AutoCAD has a command called Inventor Link, which can link Inventor iam/ipt file to the Model Space in AutoCAD. I am not sure if Civil 3D has the same command enabled. You may want to try it.
Many thanks!
Software Test Engineer
