Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
complex 3d geometrical form - guidance
12 REPLIES 12
Message 1 of 13
steve
587 Views, 12 Replies
Hi
Does anyone have any ideas for an efficient and flexible way to create this kind of geometry using Inventor? I just don't know where to even start.
Many thanks in advance for your thoughts
12 REPLIES 12
Message 2 of 13
kacper.suchomski
in reply to: steve
Hi
If we assume that the edges of the polygons lie on one plane, it is enough to sketch all the lines (polygons), offset the plane and draw a second sketch with points. Finally, use the Loft command multiple times.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 13
EdvinTailwind
in reply to: steve
Unfortunately Inventor froze and crashed when I was doing this, so I don't have my test part to share (I hadn't saved anything....) except for a screenshot below. I did this rather hasty, so there are likely improvements on this, but here's my step-by-step to achieve it:
  1. Make two parallell planes - one for the lows and one for the highs (aka peaks).
  2. Make a 2D-sketch with the desired rectangular size - looks like around 2 x 8 meters on your picture - on the low plane.
  3. Place any number of randomly positioned points inside the rectangle. If you have a front facing image of the pictured wall you can  use that as a reference.
  4. Create another 2D-sketch on the high plane. Make an exactly same size rectangle on top of the other.
  5. Repeat step 3 on the new plane. These will be the peaks.
  6. Hide the Planes for better visibility.
  7. Create a  3D-sketch. Use the Include Geometry to pick up the lower rectangle, then right-click -> Break Link. This is to enable the Split command. Because wherever the lines are attached to the rectangle, you must do a split.
  8. Start connecting the points with the Line tool. This is rather time consuming and my CPU fan started spinning like insane, so don't stress and save often! 🙂
  9. The low points should often be connected to each other, while the high ones only will connect to the low ones (unless you want ridges).
  10. Once the lines are done you can exit the 3D-sketch and start using the Patch tool. Create new surfaces by selecting the edge of each triangle (this is where you will notice if you have forgotten any lines or missed any splits). The 3D-sketch needs to be shared to enable it for multiple patches.
    (This is where my process froze, so some assumptions here)
  11. When all triangles are patched you can use Stitch to create a single surface, which then can be made into a solid with the Thicken tool.
Message 4 of 13
Hmm, in AutoCAD (sorry for cheating) I used a small LISP to create randomly placed points and then triangulate between these points.
>>Video<<
I'm sure, in Inventor a similar procedure (iLogic ?) can be used, But I have not the needed knowledge.
Jürgen Palme
Message 5 of 13
cadman777
in reply to: steve
No.
Grasshopper in Rhino3D: Advanced design.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 6 of 13
89198826955
in reply to: cadman777
if I understand correctly
pattern repeats
Снимок.JPGСнимок1.JPG is it the way you want it?
Message 7 of 13
steve
in reply to: steve
Hi
Many thanks
This the principle, but the edges are sharp (extrude backwards). This is not the exact design this is the inspiration for what I need to achieve. No the pattern does not repeat.
Message 8 of 13
steve
in reply to: j.palmeL29YX
That is brilliant. I don't mind using acad, but that is way above my skill level.
Message 9 of 13
steve
in reply to: kacper.suchomski
yes all base on one plane all points on another. Thanks I'll give is a go.
Message 10 of 13
steve
in reply to: EdvinTailwind
This seems like a real labour but it is a solution that I have the skill set for. It gives me somewhere to start.
Message 11 of 13
steve
in reply to: 89198826955
Sorry, yes each panel is a staggered repeat of the others.
Message 12 of 13
johnsonshiue
in reply to: steve
Hi! Instead of Boundary Patch, I would use Loft to a point in this case. It should be highly doable, particularly if the pattern repeats.
Many thanks!
Software Test Engineer
Message 13 of 13
steve
in reply to: johnsonshiue
Perfect many thanks.
I didn’t know you could loft to a point.
