I'm either having a moment or I simply don't know how to do it. I suspect a little of both. I have a completely closed contour rolled barrel and wish to create a flat pattern. Please indulge me and tell me how to do this. I am using IV 2022. Thanks
Solved by blandb. Go to Solution.
Solved by b.mccarthy. Go to Solution.
You cannot generate a flat pattern from a closed roll. You will have to add a seam/rip somewhere.
Contour roll wont allow you to do a 360 roll angle? Did you happen to do a thickened surface or a revolved cross sectional profile instead?
