Compatablil
Compatablil
Compatablil
Can anybody please tell me if my computer windows 10 home version 1607, OS build CPU n3450 @1.10hz 1.10 ghz , Ram 4.00, 4 GB 64 Bit  LAPTOP is compatible with Inventor 2017 pro.
admaiora
Yes. It is.
Consider that you can need more RAM, but it depends what kind of projects you will approach.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
SBix26
Almost everything in Inventor funnels through the CPU.  1.10 GHz (2.20 GHz turbo) is going to make Inventor painfully slow, even on simple models.  You also need more RAM than 4 GB.  I expect that Inventor 2017 will run, but it won't run well.
Sam B
Inventor Professional 2017.4
Vault Workgroup 2017.0.3
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
mcgyvr
System requirements are here..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
Will your laptop work for Inventor.. Yes/Probably..
Is it going to be painfully slow.. yes it certainly will..
Will it be ok for a student doing school work.. Yes/Probably..
johnsonshiue
Hi! Here is the system requirements for Autodesk Inventor 2017.
Many thanks!
Software Test Engineer
