Compare the scanned 3D model with an absolute circle in Inventor software?
long0212le
long0212le
After scanning the model with a 3D scanner, then export the file so that it can be opened on Inventor software. Is there a way to compare the scanned model with the model drawn on inventor?
Displays roundness by color.
For example, the green points have a very close roundness to the perfect circle, while the red points have a far different roundness from the circle.
JDMather
@long0212le
Did you intend to Attach some files here for comparison?
Gabriel_Watson
Try Inspect (tab) > Analyze Interference (tool) and see if it helps highlighting this for your case:
long0212le
It's not the solution I wanted, but it's a really good idea. Thank you
I want to show the same color as the attached image.
long0212le
I'm sorry but this is an internal product, I can't share it here. I'm sorry
But the place I want to check is simply whether the inside diameter of the product after machining has a good roundness?
Gabriel_Watson
I don't think Inventor is the tool for this. Unless someone here finds a "hack" in the Stress analysis environment, something wild like applying a rotation to the perfect circle and seeing how much it impacts (momentum-wise) the pieces falling outside of it.... I don't know.
admaiora
No you can't
Here a similar idea (cloud point)
https://forums.autodesk.com/t5/inventor-ideas/3d-model-cloud-points-overlap-for-shape-control/idi-p/...
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
