Command line
Command line
stephensashley
Message 1 of 10
Command line
stephensashley
Where is the command line in Inventory drawings ?
Replies (9)
Message 2 of 10
mflayler
There isn't one.  Commands in Inventor are entered through icons in the standard ribbon or by use of the Right Click Marking Menu.  You can use keyboard shortcuts as well and can be configured through the Customize command found on the Tools Tab.
You can also turn on Dynamic Prompting in your Application Options on the General Tab.  This will give you a cursor tooltip on what needs to happen next in a command.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 10
CCarreiras
Hi!
If you want to create a line in drawings, you have to create a sketch. Then you have the line command.
CCarreiras
Message 4 of 10
Mark.Lancaster
@stephensashley
Are you trying to compare Inventor LT with AutoCAD or Acad LT interface?  Don't...  Not the same software..  Smiley Wink
Mark Lancaster
Message 5 of 10
JDMather
The command - Line in Inventor drawings.
Message 6 of 10
Mark.Lancaster
2 EE's saw this as a user was looking for a command line (like in AutoCAD) and 2 other EEs saw it as the user is looking to draw a line in an Inventor drawing.
So @stephensashley which thing were you looking for?   Smiley Very Happy
Mark Lancaster
Message 7 of 10
stephensashley
I was looking for a command line like Autocad where I could enter “scale text”
type commands.
Steve Ashley
Winston-Salem, NC
336-749-1257
[email protected]
Message 8 of 10
JDMather
What standard are you using?  ANSI/ASME ?
Message 9 of 10
stephensashley
ANSI
Steve Ashley
Message 10 of 10
JDMather
Manage>Styles and Standards>Style Editor
