Color my 2D drawing?
Message 1 of 16
I'm drawing in 2D, I want to add a color to some of the objects. How do I do that?
Accepted solutions (3)
Replies (15)
Message 2 of 16
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is a forum regarding installation and licensing of Autodesk products.  What Autodesk Application are you even using to create your 2D drawings?
Mark Lancaster
Message 3 of 16
Oh, sorry, I should have added that. I have the trial Inventor Professional
version.
Peter
Message 4 of 16
Mark.Lancaster
@Anonymous
What will this drawing be used for?
Are you looking for a shaded, colored view or individual lines and etc to be in color?
Mark Lancaster
Message 5 of 16
mcgyvr
17458190_10155062378730070_2177514.2e16d0ba.fill-735x490
Message 6 of 16
Curtis_Waguespack
Hi abc123pjm,
If you're wanting to show some components shaded, then this might help:
http://inventortrenches.blogspot.com/2017/02/issue-you-want-to-create-view-on-your.html
If you're wanting to show the lines in different colors, that process might be a bit more involved. Can you provide more details, or some screen shots of the result you're wanting?
I hope this helps.
Curtis
Message 7 of 16
kelly.young
Autodesk Support
Autodesk Support
@Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
What is your current level of experience with Inventor? In the part (.ipt) environment you would set a Material and Appearance
but lines will show up in the drawing (.idw) environment as black by default, you can set the view to Shaded to show the material color.
If you want the lines to be a custom color go to the Annotate Tab > Edit Layers > New... > change Color and Line Type, Weight etc. > Save and Close. In drawing select lines, go to the Format area and set the lines to this new layer.
If you have a part you could post or a better clarification of what you are trying to do let us know!
Message 8 of 16
Curtis_Waguespack
Hi abc123pjm,
Just to add to kelly.young's post, you can quickly select all of the lines for a particular component, by expanding the view browser node and finding the component, then right clicking on it and choosing one of these options:
  • Select As Edges - simply gathers all of the component edges to the current selection set, and then you would go to Annotate > Layers and choose a layer to put the edges on (assuming you've set up some layers and layer colors previously)
  • Properties - brings up a dialog that allows you to set all of the component edges to have a certain line type, color, etc. It's actually a bit like using a box of crayons as mcgyvr joked, and doesn't provide a quick way of making changes to the colors, but you don't need to create or modify any layers
I hope this helps.
Curtis
Message 9 of 16
Hi, I've included a screenshot. I want to fill in the area of the outlined M.
It's been a long time since I've used an Autodesk program. So I have to ask
questions about simple operations. How might I fill in the M? Thanks.
Peter Murr
Message 10 of 16
 The crayons were very cute. I like your sense of humor. That is exactly
 what I want, but using the application. I've included a screen shot.
 Thanks.
Message 11 of 16
Curtis_Waguespack
Hi abc123pjm,
It appears that you are asking about filling in an region of a 2D sketch in a part file (*.ipt). I think this is a bit different than what everyone thought you were asking about, due some confusion over your use of the term "drawing".
What you show is not considered a drawing in Inventor, but instead it is considered a sketch in a part file. A drawing in Inventor is an *.idw or *.dwg file, that you use to create views and annotation to a model file, such as a part (*.ipt) or assembly (*.iam).
There really is no way to color fill a region of a sketch in a part file that I am aware of.
Can you explain what your end goal is? And then maybe someone can direct you to the correct tools.
I hope this helps.
Curtis
Message 12 of 16
kelly.young
Autodesk Support
Autodesk Support
@Anonymous I can see that you have a few issues with your sketch, primarily the .000 dimensions that are never a good sign! Get used to using constraints in your sketch. If you R+Click on a line and Close Loop it will find any open areas. You most likely are wanting to Extrude to create the solid around the M.
Post your part and we can point you in the right direction and clear up any confusion quickly. Here is a screencast that should help.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 13 of 16
Here is my finished drawing, done as only Autodesk can do.
I love Autodesk and it's series of excellent products. If I ever
win the Lottery, or accumulate the cash resources necessary
to bring my technology to market. One of the first things I'm
going to do is get Inventor. I thank you all for your advise.
Your all were so considerate.
Peter Murr
Message 14 of 16
Peter Murr
Message 15 of 16
Peter Murr
Message 16 of 16
Peter Murr
