IGS file assembly
IGS file assembly
Message 1 of 11
IGS file assembly
Hi
A company send me a machine in IGS file. All the individuals parts open fine in Inventor but I can't see nothing when I open the assembly. All the parts are in the same folder.
Do I need to do come steps to open that correctly or I can't do that?
Replies (10)
Message 2 of 11
Lewis.Young
Hi there,
Is it possible for you to share the file so that i can have a look for myself?
Lewis
Message 3 of 11
I would like to do it but is a Medtronic confidential design. 😕
Look this screen shot. I see the part .ipt but not the .iam
Message 4 of 11
Mark.Lancaster
@Anonymous
Are you referring to the browser info you have outlined in your browser image?  If so that's still a part..  Its not an assembly.  Look at the browser icon.
Mark Lancaster
Message 5 of 11
No, That was selected but not to highlight.
Look this one. Any part open fine but the assembly does not.
Message 6 of 11
kelly.young
Autodesk Support
Autodesk Support
@Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
When you expand the > of the .ipt in the model tree what shows up, are the parts showing up as a surface that is suppressed? Or possibly turn the visibility on? That would be my first guess when importing 3rd party files. If you can provide a bit more info or delete out all but a few basic/non-proprietary files and post? Thanks!
Message 7 of 11
JDMather
In addition to surface Visibility-
another problem could be a "floater".
If you delete all but one part from the assembly and do a Zoom All - does the remaining part show in the assembly?
Message 8 of 11
Thanks for welcome.  I'm just a beginner 🙂
Is this mean that no part is in the tree?
Message 9 of 11
JDMather
In the assembly browser - click on this black symbol > and then post new screenshot image here.
Message 10 of 11
johnsonshiue
Hi! I think the bodies are probably in Construction Environment in each part. You may want to re-import the IGS file but set the destination to Repair Environment.
Many thanks!
Software Test Engineer
Message 11 of 11
JDMather
Can in include a screen capture of the part file showing the expanded browser?
