collision detection of entire assembly
I am working with assemblies with a lot of sheet metal parts.
It happens that a constraint is wrongly placed or that I add a flange to a part without checking if it still fits in the assy.
Is there a way for Inventor to auto-check if bodies collide or overlap?
All I've found is the interference analyser, but it can only analyse two sets, and I need it to check the entire assy.
Thanks for any help!
JonathanMLanderos
Here's a trick that might help.
Pick all your components as Set 1.  Ignore Set 2 (leave the arrow red).
The interference check will still run, but Inventor will check all the components in set 1 against each other.
Word of warning, if you have a lot of components selected in set 1, the analysis could take a while.
It is possible to fly without motors, but not without knowledge and skill.
Wilbur Wright
mcgyvr
http://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/201...
