Coil axis intersects profile Error
cameron.lightfoot9W9RQ
I'm having an issue when trying to coil this sheet metal part, attached below is 2 .Ipt files, one that works and one that doesn't.
This is the first time I've come across this issue and I've done about 4 or 5 of these twists now, if anyone has any advice or fixes for the issue I would greatly appreciate it.
Below are the coil setting and the error message for part 5.
Thank you in advance for any help.
Part 5 Coil Settings 1Part 5 Coil Settings 1Part 5 Coil Settings 2Part 5 Coil Settings 2Part 5 Error MessagePart 5 Error Message
wrw0007
Forgive me as I am not well versed in coils...
What I've gathered is that the only difference between the two parts is the profile used. Some experimenting tells me that the error occurs when the width of the profile crosses the threshold of the axis being used. See the attached image. I highlighted the problematic portion of the profile. This same issue would occur if you make part 1 wider. Part 5 would work if it was all to the left of the axis. Why this happens? I don't know off the top of my head and cannot formulate my speculation into words.... so basically I'm boiling it down to a geometric impossibility.
What I can offer is a workaround. You'll have to try it out and let me know if it works exactly for your needs.
I've attached a modified part. Basically I coiled the inner surface and then thickened it to the proper thickness. This ensures that you have a uniform thickness and profile throughout and works around that "geometric impossibility" that I pulled out of my butt. Maybe somebody smarter than me can better explain it.
Edit: It doesn't matter which side of the axis it is on, it just can't be on both. I'm assuming because the axis is skewed and not normal to the sketch.
SBix26
See attached-- I don't know the details of why your original didn't work, but here's what I did to fix it: I moved the 3D sketch where you defined the axis of the coil to the top of the browser (first feature), then redefined Work Plane 1 to be perpendicular to that axis at the endpoint.  This makes the profile perpendicular to the coil axis rather than perpendicular to the Y-axis (about 1/2° off the coil axis).
Hope this gets what you need.
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
This worked almost perfectly thank you.
The profile is a little bit off but will do, should be able to sort any deviation in fabrication tolerances.
I appreciate the quick response and the help, thank you once again.
johnsonshiue
Hi! Another workflow to consider is to use Twist Sweep. Sweep the profile along the path. Then add a twist angle so that the profile can rotate from the start til the end.
Software Test Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
