Clipping when rendering?
jgjYRRKE
jgjYRRKE
Hi all.
When i render an animation in Inventor 2020, using Studio i get annoying lines from parts that should not be visible.
Can i get rid of that without changing the parts just for rendering purposes?
The rendering is PREVIEW ONLY, since me PC do not have the required power to do a real rendering.
(unless i use weeks of rendering)
Thank you.
Jesper from Denmark.
johnsonshiue
Hi! Could it be due to very thin wall thickness? Inventor graphics system may display the back edges bleeding through when the front body thickness is small.
Many thanks!
Software Test Engineer
jgjYRRKE
Yes, it is only a few mm. thick.
So i guess nothing can be done then?
johnsonshiue
Hi! The only way I am aware of is to turn off edge display. Go to View -> Visual Styles -> Shaded.
Many thanks!
