Clarity of Assembly Degrees of Freedom
Can we have some clarity from the Degrees of Freedom found in Assemblies.
For example, I can't find any Legend within the various bit of documentation, it would be helpful.
How are we supposed to know which glyphs apply to which components ?
Or, is there a simple way of finding out ?
Is there anyway of checking the Asm-DoF of individual components of selected components within an assembly ?
What doesn't Asm-DoF show if Limits are applied to different constraints ?
Why can't we select a Asm-DoF and it'll tell us which component it applies to ?
stuart_smith82
You can animate degrees of freedom. This will give you a list of components with linear and rotational degrees of freedom remaining, it will also animate the movement in the part.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Kind Regards
Stuart Smith
Graitec UK Manufacturing
@stuart_smith82  thanks for your response.
I wasn't aware of the animated DoF tool within the  "productivity tools".
I've previously used View (tab) -> Visibility (panel) - DoF.
I know you can answer some of these questions, but hopefully an Adesk employee will be passing.
Why aren't they (DoF tools) collected together in the same place ?
Can the dialogue box be changed to a Window, insofar as the edges can be dragged to resize it.
When a component/part is selected in the box/window can it be highlighted in the assembly.
If a part/component is first selected and then that functionality chosen, will it just analyse that one component/part.
Can the relationships to other parts/components be shown in that dialogue box/window.
Can components/parts be grounded from that box/window and then the analysis re-run, so we can see the effects.
Can the result be exported to a M$ Word docx or similar so we can monitor the improvements.
Hopefully a young JeDI will be passing and do these changes before break fast Cat Very Happy
