Circular pattern using distance
I need to do a circular pattern of a hole on a 45 degrees arc length. But it can't be based on a quantity of occurrences. I need one specific distance between each hole, lets say every 300 mm. I just can't figure out the formula required to obtain the result I'm looking for.
Does anyone remember how to do this?
JDMather
Sounds like a Curve Driven Pattern.
Can you attach your file here?
you probably know this by now but:
  • if 300 is measured along chord (straight line) than you will have one hole every alpha = 2* asin(0,5*300/R)
  • if 300 i measured along arc (arc length) than you will have one hole every alpha [deg] = 360 [deg] * 300 / (2 * Pi)
in inventor you do not have to calculate any of those. Just do a additional sketch, or use one you have and in pattern make a link to appropriate dimensions.
would you need an example? if so post your file please.
Cris.
It seems I found a solution to my two related post. See below the link to it.
http://forums.autodesk.com/t5/inventor-general-discussion/hole-pattern-on-curve-surface/m-p/5502193#...
