Message 1 of 9
I think the images speak for itself. The bottom beam of the original feature/support is at 389 mm height. I need a circular pattern on the entire support. When I create the pattern, the bottom beam is somehow moved up to 872 mm. The preview of the circular pattern shows how it should be. I can not figure out what is causing this. Does anyone have an idea?
I attached a simplified ipt.
Using Inventor 2019.
