Circular pattern changes position of feature
gert-leonvanlier
Message 1 of 9
gert-leonvanlier
I think the images speak for itself. The bottom beam of the original feature/support is at 389 mm height. I need a circular pattern on the entire support. When I create the pattern, the bottom beam is somehow moved up to 872 mm. The preview of the circular pattern shows how it should be. I can not figure out what is causing this. Does anyone have an idea?
I attached a simplified ipt.
Using Inventor 2019.
Replies (8)
Message 2 of 9
admaiora
Are you aware of those iLogic rules inside? I presume that can be the cause
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
admaiora
Editing, withount change, the pattern feature and than OK, seems to fix it
Admaiora
Message 4 of 9
gert-leonvanlier
Yes, I am aware of the iLogic rules. They are mine.
Message 5 of 9
gert-leonvanlier
You mean editing SupportCurvePattern and then OK? That doesn't work. The preview is as it should be, but after that it is wrong.
Message 6 of 9
gert-leonvanlier
I built the features from scratch and now it is working. Although I got two errors where a sketch could not be created. Very strange, but I solved it using work planes.
Message 7 of 9
johnsonshiue
Hi! I recalled there was a bug in 2018 when Sketch-Driven Pattern was introduced. Then it got fixed in one of the updates on 2019 or 2018 I don't recall exactly. Rebuild All in later releases should fix it too. If you see the behavior again, please let us know.
Many thanks!
Software Test Engineer
Message 8 of 9
gert-leonvanlier
I think the bug is still there, because it's happening again, although it was gone for a while.
Message 9 of 9
johnsonshiue
Hi Gert,
If possible, please share an example that exhibits the behavior. Just to double-check. Please make sure you select a logical base point from the source feature.
Many thanks!
