Circular Pattern Axis Inaccessible After Mirror Pattern
I encountered an issue with the Mirror Pattern feature. I'm on Inventor Professional 2026.3
When mirroring an assembly/part together with a Circular Pattern, where the Circular Pattern has its Direction Axis defined using an axis from the assembly/part being mirrored, I cannot redefine or change the axis afterward because the original assembly/part is invisible/hidden.
In the example below, the bearing unit and the bolted connections are mirrored to the other side of the shaft. When I replaced the bearing unit with another part, the Circular Pattern of the bolted connections lost its Direction Axis reference.
When I try to edit the Circular Pattern and select another circular face from the new bearing unit, I cannot select it because the original bearing unit is hidden.
The current workaround is to delete the Mirror Pattern, redefine the Direction Axis, and then create the Mirror Pattern again, which is not ideal.
Is there a way to redefine the Direction Axis without deleting and recreating the Mirror Pattern?
Is this a known limitation, or is a fix planned for a future Inventor update?
Thanks!
